What's it cost to have a Briggs 8 hp engine overhauled?
   / What's it cost to have a Briggs 8 hp engine overhauled? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
While our power was out we were running on our 4 yr old generator and it started surging, then it got worse, then backfiring, then emitting flame out the exhaust, 6" diameter, then 8-10 long flame, then it quit running.
Has been a good generator, would like to have it overhauled and put back to use. So, what's an overhaul roughly cost? Thanks.
   / What's it cost to have a Briggs 8 hp engine overhauled? #2
Probably more than a new engine.
Sounds like a timing or valve issue, might have been able to save it. Does it still have compression?
   / What's it cost to have a Briggs 8 hp engine overhauled? #3
Could be as simple as an ignition problem or carb.
   / What's it cost to have a Briggs 8 hp engine overhauled? #4
Would a new Harbor Freight Predator fit?
   / What's it cost to have a Briggs 8 hp engine overhauled? #6
Love my Predator powered generators and semi trash pump!
   / What's it cost to have a Briggs 8 hp engine overhauled? #7
   / What's it cost to have a Briggs 8 hp engine overhauled? #8
Look up your Briggs numbers and compare it to this Predator list. See if you can find one that's compatible.
attachment.php
   / What's it cost to have a Briggs 8 hp engine overhauled? #9
Small engine shops generally charge about $100 just to look at it. If "they" determine you need a crank, rod or piston you'll already be over the cost of a new engine. Even a valve job will get you close to the cost of a new engine these days. And if you go with a repair, you'll still have an old engine. :confused3:
Forgot to mention: DuroMax is another good replacement engine.
   / What's it cost to have a Briggs 8 hp engine overhauled? #10
This. Likely needs some carburetor work or even just try a new spark plug. Overhaul may have meant tune up? Plus generators can have different crankshaft ends for those that choose to repower.
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A55787)
2019 John Deere...
2008 Cat D4K XL Dozer (RIDE AND DRIVE) (A50775)
2008 Cat D4K XL...
