What's it cost to have a Briggs 8 hp engine overhauled?
   / What's it cost to have a Briggs 8 hp engine overhauled? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
While our power was out we were running on our 4 yr old generator and it started surging, then it got worse, then backfiring, then emitting flame out the exhaust, 6" diameter, then 8-10 long flame, then it quit running.
Has been a good generator, would like to have it overhauled and put back to use. So, what's an overhaul roughly cost? Thanks.
   / What's it cost to have a Briggs 8 hp engine overhauled? #2
Probably more than a new engine.
Sounds like a timing or valve issue, might have been able to save it. Does it still have compression?
   / What's it cost to have a Briggs 8 hp engine overhauled? #3
Could be as simple as an ignition problem or carb.
   / What's it cost to have a Briggs 8 hp engine overhauled? #4
Would a new Harbor Freight Predator fit?
   / What's it cost to have a Briggs 8 hp engine overhauled? #6
Love my Predator powered generators and semi trash pump!
   / What's it cost to have a Briggs 8 hp engine overhauled? #7
   / What's it cost to have a Briggs 8 hp engine overhauled? #8
Look up your Briggs numbers and compare it to this Predator list. See if you can find one that's compatible.
attachment.php
   / What's it cost to have a Briggs 8 hp engine overhauled? #9
Small engine shops generally charge about $100 just to look at it. If "they" determine you need a crank, rod or piston you'll already be over the cost of a new engine. Even a valve job will get you close to the cost of a new engine these days. And if you go with a repair, you'll still have an old engine. :confused3:
Forgot to mention: DuroMax is another good replacement engine.
   / What's it cost to have a Briggs 8 hp engine overhauled? #10
This. Likely needs some carburetor work or even just try a new spark plug. Overhaul may have meant tune up? Plus generators can have different crankshaft ends for those that choose to repower.
2020 Ford F-150XL (A53314)
2020 Ford F-150XL...
2008 Ford F-350 Service Truck (A55788)
2008 Ford F-350...
23013 (A55787)
23013 (A55787)
2015 Ford F-250 (A53314)
2015 Ford F-250...
UNUSED AGT TAS-50X PTO Driven Tiller (A47477)
UNUSED AGT TAS-50X...
