What's going on here
/ What's going on here #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
What\'s going on here
Found the following at the top of this page.
Warning: mysql_connect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (13) in /home/tractorb/htdocs/forums/mysql.inc.php on line 58
SQL ERROR: Sat, Dec 04 2004 15:16:04 -0600 Database error only visible to forum administrators
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/tractorb/htdocs/forums/mysql.inc.php on line 68
/ What's going on here #2
Re: What\'s going on here
I have seen them errors before a few times. I found that you just log out and back in and everything should be ok. If TBN's servers are down or doing updates you will also run into them errors.
murph
/ What's going on here #3
Hey Guys,
You should check Who's Online when errors like that happen. If you see me, I'm probably breaking stuff. I was fixing the search, and a few other things. I discovered a bug the hard way, and it took me a while to fix it. But I got it fixed. And the message is gone. /forums/images/graemlins/wink.gif
Thanks for the patience. If you notice anything else weird, feel free to post up. But a quick check of Who's Online will usually get you a good idea if I'm messing with stuff. /forums/images/graemlins/smile.gif
-Ibrahim
/ What's going on here #4
Ibrahim,
<font color="blue"> Generated in 16.978 seconds in which 16.944 seconds were spent on a total of 16 queries. Zlib compression enabled. </font>
About 6:20PM EST just trying to read a post in Owning/operating. Muhammad and Hakim are online, but not you.
/ What's going on here #5
Thanks,
Keeping an eye out. It might've just been a strange hiccup. Things are still running, overall, smoothly.
-Ibrahim
/ What's going on here #6
Right after, that I also got a full screen of MySql errors on another post. But when I hit refresh it was back to normal.
/ What's going on here #7
Yeah, that was me restarting it for a log file to be re-written.
-Ibrahim
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
SCAN TO RECEIVE TEXT UPDATES (A64278)
SCAN TO RECEIVE...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
New - Front mount rototiller
New - Front mount...
