What's going on here
/ What's going on here #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
What\'s going on here
Found the following at the top of this page.
Warning: mysql_connect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (13) in /home/tractorb/htdocs/forums/mysql.inc.php on line 58
SQL ERROR: Sat, Dec 04 2004 15:16:04 -0600 Database error only visible to forum administrators
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/tractorb/htdocs/forums/mysql.inc.php on line 68
/ What's going on here #2
Re: What\'s going on here
I have seen them errors before a few times. I found that you just log out and back in and everything should be ok. If TBN's servers are down or doing updates you will also run into them errors.
murph
/ What's going on here #3
Hey Guys,
You should check Who's Online when errors like that happen. If you see me, I'm probably breaking stuff. I was fixing the search, and a few other things. I discovered a bug the hard way, and it took me a while to fix it. But I got it fixed. And the message is gone. /forums/images/graemlins/wink.gif
Thanks for the patience. If you notice anything else weird, feel free to post up. But a quick check of Who's Online will usually get you a good idea if I'm messing with stuff. /forums/images/graemlins/smile.gif
-Ibrahim
/ What's going on here #4
Ibrahim,
<font color="blue"> Generated in 16.978 seconds in which 16.944 seconds were spent on a total of 16 queries. Zlib compression enabled. </font>
About 6:20PM EST just trying to read a post in Owning/operating. Muhammad and Hakim are online, but not you.
/ What's going on here #5
Thanks,
Keeping an eye out. It might've just been a strange hiccup. Things are still running, overall, smoothly.
-Ibrahim
/ What's going on here #6
Right after, that I also got a full screen of MySql errors on another post. But when I hit refresh it was back to normal.
/ What's going on here #7
Yeah, that was me restarting it for a log file to be re-written.
-Ibrahim
Frac Manifold T/A Trailer (A64194)
Frac Manifold T/A...
Bulk Hog Feeder (A66408)
Bulk Hog Feeder...
Chair (A64557)
Chair (A64557)
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
