What's Behind Me??
/ What's Behind Me?? #1
T_HedMF1533
SW VA, SW FL
'06 Massey 1533, 08 Massey 1552,15 gc1705
Hey folks I am thinking about putting rearview mirrors on my MF 1533.
I need some ideas of different types and where to mount them out of the way. Can you guys help me out with some ideas/pics of your mirrors.
I don't have a cab or canopy so my choices are few I would think.
Thanks in advance for your help.:D
T
/ What's Behind Me?? #2
T
Since you don't have a canopy, the best place to put a mirror would be on the loader uprights. Do you have a loader?
/ What's Behind Me?? #3
Get yuo some of those extended bar side view mirrors like 'large' trucks have., and mount them to the hood, to the left or right of you. or get a side view and mount it on the outter edge of a fender, ahead of you.. if you have enough clearance.
I''l bet that tube frame side view mirror holder from a junkyard would be 10$ or less.
Soundguy
Jerry, Yes I have a loader. On the uprights? Ok So.... Drill n tapto mount the
mirrors?
Soundguy, I may have to check out the local JYD, thanks for the input!
T
/ What's Behind Me?? #5
You can get those 3" (maybe bigger) convex mirrors at a lot of stores that just have adhesive. Might be lucky enough to have a space to just stick em with no work. Theyre normally pretty cheap too
/ What's Behind Me?? #6
Thats what I added to the left hand side of my own FEL...but Im going to add another mirror also.
Many mirrors for motorcycles have a threaded stud and a gimbal ball mount...so I'll need to drill and tap a hole in the FEL mount and screw the mirror in and then adjust so I can see with it and then tighten down on that ball mount. The stems come in various lengths.
/ What's Behind Me?? #7
Get a universal motorcycle mirror that has a male stem that slides into a hole that is usually on handle bar controls and then weld a short piece of tubing on the outside edge of your FEL upright and install mirror. I have one on mine and if I get to close to something, it only flips the mirror around, not break it. You can get one for both sides too.
My Kubota came with the tubing all welded on.
I will post a picture when I catch up to my tractor again this week. It is living on a wood lot this winter.
Mainiac
/ What's Behind Me?? #8
One thing to be sure of-place them where they won't break any thing when they come off - I've placed several mirrors on my tractor that have been quickly removed by those tree limbs that reach out and grab them. And most of the time I couldn't use them because of the vibration while running.
MikeBurr, I never thought about the vibration, are mirrors worth the time and effort?
T
/ What's Behind Me?? #10
I stopped asking "What's Behind Me??" when I turned 50 ;)
I was thinking about putting these Harley staulk mirrors I have, hanging down from my canopy. But I was also wondering about vibration.
Putting those round mirrors on the loader uprights is a nice idea. Not sure it would be high enough...but definately better than nothing.
/ What's Behind Me?? #11
Wierd but works. As old peddle bike racer I am comfortable with 3/4 inch mirror attached to hat. Check local bike shop. Typically under $5. Can't see something-move head. Takes some getting used-to but works great for me.
/ What's Behind Me?? #12
I really like the mirrors on my L4610HSTC Kubota. They could be adapted to work on many other setups. They fold out of the way easily by hand or when they hit an obstruction(going forward or reverse.) That is important as some fold away mirrors don't fold away when backing (for example the big fancy electric retractable after market mirrors on my one ton Dodge/Cummins.
You really have to work at it to break one of the Kubota mirrors. I did it but it took years of driving through brush like a crazy man (I had no choice if I wanted to drive.)
Pat
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2016 Chrysler Town and Country Van (A61574)
2016 Chrysler Town...
Cat 262D Wheeled Skid Steer (A64047)
Cat 262D Wheeled...
2021 CAM p4EC16W102 16ft. 7000lb Utility Trailer (A64047)
2021 CAM...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
