What would you use to glue seat back down?
   / What would you use to glue seat back down? #1
clemsonfor
Super Member
Greenwood Co., SC
Yanmar YM2000
I was given a zero turn that needed some work. It's low hours. I did the needed repairs to get it back in service. Now it's just things like the hour meter doesn't work and the fuel float is sunk so the gauge doesn't work. But the question I have is the seat has pulled away from the metal seat pan/back. I see many mowers do the very same thing. I want to see what your suggestions to glue the outer rim of the vinyl seat back down to the metal back would be? It came from the factory with some kind of glue in there. I can't remember if it felt like silicone at this point without going back out there.
Would you use a liquid nails, silicone adhesive, a special tractor seat glue that i dont know exists, or some sort of other glue? Let me hear your thoughts on this?
   / What would you use to glue seat back down? #2
I like goop for almost every thing. I don't know if it would work on the vinyl. Does well with the vibration. I use it on everything.
   / What would you use to glue seat back down? #3
Liquid Nails - one 14oz tube in your calk gun.
   / What would you use to glue seat back down? #4
Find a tube of this......MasterSeal NP 1 elastomeric polyurethane sealant
Sticks to everything and doesn’t harden so it won’t crack. We use it to glue aluminum caps on in the field. Hot, cold, rain or snow it always works. Everything else we have tried failed
   / What would you use to glue seat back down? #6
Just about anything 3M makes is good.. The Liquid Nails is GREAT but don't expect to ever take it off again.. lol
I spray can of 3M adhesive
   / What would you use to glue seat back down? #7
Just picked up a roll of yellow duct tape to temp repair the seat on my JD. Ace Hardware sells it.
   / What would you use to glue seat back down? #8
I used liquid nails, because I had it. Looks a bit white around the edges but still holding two years.
I had the same thought about liquid nails and never removing it. But if I had to it would be to get a new seat I guess and it would just be similar to a foamed tire. Cut the seat off and grind the mess out of the metal pan before I replaced it.
I may look into the 3m weather strip adhesive and also the masterseal. That sounds like just what I need to glue back down the pipe cap/top plate on my chimney (at the farm) that came loose with silicone.
   / What would you use to glue seat back down? #10
I use Mean Green spray adhesive to glue my seat back to the pan. You spray both sides, wait till it is tacky then stick both together for instant bond.
I get it from my local HVAC supply house. I think they must use it to attach the foam boards inside AC ducts. I have also used it to secure weather stripping.
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
TRUCKING INFO (A50774)
