What would you like to see the tractor manufacturers to make.
   / What would you like to see the tractor manufacturers to make. #21
Self leveling loaders available for all tractor sizes right down to the smallest.
Why do you have to buy a 65 HP tractor to get a self leveling loader?
Ridiculous!
   / What would you like to see the tractor manufacturers to make. #22
Ridiculous!
O.K.; fine.
It's worth reading twice I guess.
   / What would you like to see the tractor manufacturers to make. #24
Another vote for smaller (compared to the New Holland offering) and simpler bi-directional articulated tractors with big tires front and rear. PTO & 3pt at both ends. Loader at cab end.
   / What would you like to see the tractor manufacturers to make. #25
Wider ag tires for the front 16" wheels on CUTS and with heavier plies. Most who buy a 25-45 HP CUT in 4wd are also getting it with a loader. And 7x16 or 8x16 tires are just too skinny and make big ruts with a loader.
Would also like larger front tires (diameter) offered in the smaller framed tractors. Short tires ride rough.
Better hydraulic hose protection underneath. (I fabbed a skid plate to protect my hoses and filter after a few near misses)
Develop a radiator that dont plug up with crap when brushhogging in the fall:thumbsup:
They used to have that. ... Forgot how to make em I guess. Progress integrated over Time = Zero
   / What would you like to see the tractor manufacturers to make. #26
I would like to see a heated steering wheel for snowplowing. It's always the fingers that get cold. Also larger capacity hydraulic pumps.
   / What would you like to see the tractor manufacturers to make. #27
I always admired the loader Xfaxman built based on a used mower. Some pics here: http://www.tractorbynet.com/forums/...s-weak-how-check-post4314958.html#post4314958
Thanks Mace. For those that haven't seen it, here is the rest of the story: http://www.tractorbynet.com/forums/customization/272163-fel-toro-groundsmaster-put-together.html
   / What would you like to see the tractor manufacturers to make. #28
Get rid of the 3ph forever and come up with something easy and standard like a quick hitch.
At least the option of having an auto shutdown in case of "out of limit" condition, for stationary use.
   / What would you like to see the tractor manufacturers to make. #29
A model with sliding ballast could be a real boon for hill country work.
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58216)
2008 TEXAS BRAGG...
JOHN DEERE 261 GROOMING MOWER (A52708)
JOHN DEERE 261...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
2021 Caterpillar 272D3XE High Flow Compact Wheel Loader Skid Steer (A55973)
2021 Caterpillar...
2010 MULTIQUIP 25KW GENERATOR (A58216)
2010 MULTIQUIP...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
