What would you like to see the tractor manufacturers to make.
   / What would you like to see the tractor manufacturers to make. #151
   / What would you like to see the tractor manufacturers to make. #152
   / What would you like to see the tractor manufacturers to make. #153
Nah, if you aint happy in 645 hours, I am guessing you aint going to be happy with the treadle.
OK show of hands.. who likes treadle pedal? Who likes side by side? Who is happy withe either? I am in the either camp.
Come to think of it, I believe it would be very easy for a manufacturer to design a treadle peddle that you can rotate 90 degrees and use either way. Turn it one direction (straight up and down), it gives you the standard treadle pedal. Pull a pin to unlock it, rotate it 90deg CW, and you have a side by side. At least, it seems like it wouldn't be that hard for some bright, young mechanical engineer to design one. :laughing:
I personally prefer the side by side.
   / What would you like to see the tractor manufacturers to make. #154
That is not a bad idea.
   / What would you like to see the tractor manufacturers to make. #156
I really, really would like to see EVERY tractor designed with a Tool Box for spare lynch pins, link pins, shear pins, wrench, etc. Insane to not have an OEM factory tool box on every tractor. I had to mount a 50cal ammo can to carry vital items.
   / What would you like to see the tractor manufacturers to make. #157
I agree, a tool box on the brush hog, would solve issue too. HS
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
NEW Wolverine 72in Skid Steer Ripper (A59000)
NEW Wolverine 72in...
2021 Ford F-250 (A55973)
2021 Ford F-250...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
