What would you like to see the tractor manufacturers to make.
   / What would you like to see the tractor manufacturers to make. #151
   / What would you like to see the tractor manufacturers to make. #152
   / What would you like to see the tractor manufacturers to make. #153
Nah, if you aint happy in 645 hours, I am guessing you aint going to be happy with the treadle.
OK show of hands.. who likes treadle pedal? Who likes side by side? Who is happy withe either? I am in the either camp.
Come to think of it, I believe it would be very easy for a manufacturer to design a treadle peddle that you can rotate 90 degrees and use either way. Turn it one direction (straight up and down), it gives you the standard treadle pedal. Pull a pin to unlock it, rotate it 90deg CW, and you have a side by side. At least, it seems like it wouldn't be that hard for some bright, young mechanical engineer to design one. :laughing:
I personally prefer the side by side.
   / What would you like to see the tractor manufacturers to make. #154
That is not a bad idea.
   / What would you like to see the tractor manufacturers to make. #156
I really, really would like to see EVERY tractor designed with a Tool Box for spare lynch pins, link pins, shear pins, wrench, etc. Insane to not have an OEM factory tool box on every tractor. I had to mount a 50cal ammo can to carry vital items.
   / What would you like to see the tractor manufacturers to make. #157
I agree, a tool box on the brush hog, would solve issue too. HS
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2011 GAYLEAN 130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN 130...
2009 Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
2009 Kubota...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
Kubota B2301 (A53317)
