What Would You Bid ?
   / What Would You Bid ? #2
ZERO...
BIL bought a couple like that and although they were sealed the diesel was crap. Looked like it had been sitting around for years. I think it has ended up as weed control because I don't think it would even burn. Be careful.
   / What Would You Bid ? #3
Ditto, my bid would be zero too, unless you like you like to pay for hydrocarbon eating microorganisms.....
   / What Would You Bid ? #4
hand pump worth $20?
   / What Would You Bid ? #5
LBrown59 said:
2 55 gallon drums of diesel fuel.
one has a hand pump the other one don't.
This is comming up at a local farm Auction.
I'd have to check our mechanics shop and see what the disposal fee is for diesel fuel....Then I'll tell you how much I'd charge to haul it away.;)
Diesel stored in barrels will collect condensation, and diesel will form alge if aged long enough. I wouldn't touch it with a TWENTY foot pole for use in a tractor without full knowledge of it's age and how it was stored. If you've ever had a fuel system (on a tractor) get contaminated with dirt/alge/water/ect, you'll be very hesitant to use fuel with an unknown history. Fuel filters don't catch it all.
If you happen to have a shop heater that can burn diesel, it would PROBABLY be OK for that. (I've burned garbage diesel in mine with no ill effects)
   / What Would You Bid ? #6
You can check for algea by sweeping your finger around inside the fill hole under the lid. If there is algea in the fuel your finger will get a black coating on it. If it was stored inside and looks nice and clean and the barrel is clean inside I woundn't be afraid to buy it. You can always filter it by adding inline sediment and water filters to the pump if you are concerned. My guess is that it will probably go for something like $200 plus, depending on who is at the auction.
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
377789 (A51573)
377789 (A51573)
2017 Hitachi ZX245USLC-6N (A47477)
2017 Hitachi...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
