What would keep your Grapple out of the FIRE?
   / What would keep your Grapple out of the FIRE?
Hmmm, don't think mine has shipped yet...tempted to cancel and get the new one:cool:
Don't cancel, but you can wait an extra week on the new one if you wanna.
Just give me a call and we can easily arrange it.
Travis
Here's a pic of the newly modified tine. These notches are cut for a 3/16 x ス cold roll radius on every corner for strength.
All sizes have been completed, so the new ones that we make will all be updated.
The one shown has 3 notches and is for our Compact Wicked Grapples(50"-72"). The Wicked Utility Grapples(55" and 73") will have 4.
Travis
   / What would keep your Grapple out of the FIRE? #83
That should do it. How about a pic of a finished one...
   / What would keep your Grapple out of the FIRE? #84
Travis
Why are they in the weak axis? Seems like they'd hold up better and block even less view in the other orientation. You also get more weld surface; although that's likely not an issue either way.
   / What would keep your Grapple out of the FIRE? #85
Off the top, without adding more material, the axis you're asking about potentially weakens the grapple's strength.
   / What would keep your Grapple out of the FIRE? #86
You mean on the front side? Think it would sustain a lot of damage real quick up there.
   / What would keep your Grapple out of the FIRE? #87
Eric, once you weld the bars in, there's no weakening of the plates unless you only weld one side of the joint.
Another option is to counter sink them slightly from the back edge and put a weld across the gap. Sure, it's not 100ksi, but 70k from a decent MIG filler is going to be plenty.
   / What would keep your Grapple out of the FIRE? #88
True, but think about the time it takes to production weld a lateral over a vertical axis.
Also, as a user I think a horizontal axis will be harder to unload twiggy debris than a vertical axis. Time will tell with feedback to verify.
   / What would keep your Grapple out of the FIRE? #89
I don't think those slats would add much time even with the added length of weld a horizontal orientation would have. It's going to add some time, and cost, no argument there. How much more one to the other is maybe 10 minutes per unit? Hard to say without knowing how far the bars go and how many joints are there and if they're seam welded or just stitched.
As for which way would trap less stuff - I'm not sure. I don't know if a sharp edge vertically would be less prone to grabbing than a flat in the horizontal with something stuck in between it and the next one or the jaw plates. Vertically would possibly stop more, or could just result in a smaller opening for it to get jammed in.
I think it will add to the value, especially since the price isn't going up.
I'll show pics when the first one is complete. The factory fires back up on Monday and we've had a couple of requests for the new version already.
Travis
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
KLEIN TOOLBOX (A50854)
2008 FORD F-650 (A50854)
2008 FORD F-650...
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
