Dwight
I have a
B2910 and use it regularly when I have the time and weather is good. I’ll list all the items that I have collected, bought, or made over the years to using on my tractor. I do not use all the items at the same time whenever a project comes up I do generally have the correct tools to use.
B2910 Turf Tires
Folding ROP’s
1 ½” wheel spacer for Tire Chains
Cup Holder
Oo”ga Horn
Tilt Meter
Remote Lights mounted to ROP.
402 FEL.
60” FEL buckets with Tooth Bar. Salvaged and repaired from dealer.
60” FEL Bucket has a homemade Grapple With removable tines and 3 hook attachments.
6’6” Curtis Hydraulic front blade. It is attached to the FEL using the Quick
<font color="orange"> Kubota </font> FEL pallet Forks
All of these items attach to the FEL with a Kubota Quick Coupler.
Top & Tilt. Made with help from TBN.
72” <font color="orange"> Kubota </font> MMM.
60” Land Pride Box Blade.
BL4690 Backhoe with 16” bucket.
<font color="orange"> Kubota </font> 52” reverse tine tiller.
<font color="green"> JD </font> 513 Rotary Cutter.
6” KK Disk.
72” Land Pride HD Back Blade.
84” Land Pride Landscape Rake
60” First Choice Core Aerator
Speeco 3PH Quick Coupler, Modified to allow mounting of 3PH attachments on FEL.
55-gallon sprayer with 3-½ hp motor for pump.
<font color="orange"> Kubota </font> Weight Box. Modified to have a 2” trailer stick out the back.
3PH trailer hitch.
9’ Boom Pole.
2’ slip scoop. One of my oldest attachments. Came with my Farmall Cub.
Third, Fourth. And Fifth Hydraulic output to run the Front Blade Angle, and Grapple, Top & Tilt, and Rear angling Back Blade.
16” Tamden Axle 7,000 LBS trailer.
5” Bear Cat
Chipper-Shredder. It is not run by the tractor, but I do pull it with the tractor.
4’ X 8’ Utility Trailer.
All the chains, pins, clips and other items required to attach the attachments. I must have at least 4 of each because I will not be able were I left them the last time I used them. I don’t leave them laying around. I just can’t remember where I thought the correct place was to store them.
30” X 40” Pole Barn with 10’ X 30’ Covered lean-to to store all the equipment.
I have a wish list. /forums/images/graemlins/crazy.gif
Middle Buster, Sub Soiler
Power Rake
If you stay on TBN long enough you will have as many attachments or a longer wish list. /forums/images/graemlins/grin.gif
<font color="orange"> </font>
