What weight oil -- Hinomoto e264
   / What weight oil -- Hinomoto e264 #11
I gather that this could be your first diesel tractor. If it is, don't panic.
Change the filter and the oil. Run it around the barn once. The oil will probably be dark and gross looking! That is fairly typical.
Like Buppy69 says -- an MF filter. Your local AGCO/Massey dealer should be able to fix you up with the filter. Any good "diesel-rated" multi-viscosity oil should take care of you.
Have fun with your Hinomoto. They are rough and tough little tractors.
Knute
Good answer on diesel oil. They do turn black right away.
Wes
   / What weight oil -- Hinomoto e264 #12
You’ll find your engine is a Toyosha. The rest is Hinomoto
RCcar RC-G4.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G4.0...
RIGID TOOLBOX (A52472)
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
2" X 3" ANGLE IRON UP TO 16' LONG (A51247)
2" X 3" ANGLE IRON...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53472)
Kubota BX2680...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
