What weight oil -- Hinomoto e264
   / What weight oil -- Hinomoto e264 #11
I gather that this could be your first diesel tractor. If it is, don't panic.
Change the filter and the oil. Run it around the barn once. The oil will probably be dark and gross looking! That is fairly typical.
Like Buppy69 says -- an MF filter. Your local AGCO/Massey dealer should be able to fix you up with the filter. Any good "diesel-rated" multi-viscosity oil should take care of you.
Have fun with your Hinomoto. They are rough and tough little tractors.
Knute
Good answer on diesel oil. They do turn black right away.
Wes
   / What weight oil -- Hinomoto e264 #12
You’ll find your engine is a Toyosha. The rest is Hinomoto
2016 Ford F-550 4x4 Landscape Dump Truck (A48081)
2016 Ford F-550...
2018 Toro Sand Pro 5040 Bunker Rake (A49346)
2018 Toro Sand Pro...
Kubota M4700 4WD Tractor (A50860)
Kubota M4700 4WD...
2025 Unused 2inch x 50ft Discharge Hose (A49346)
2025 Unused 2inch...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
2005 Trail King TK24LP 15 Ton T/A Tag-Along Dovetail Flatbed Trailer (A49346)
2005 Trail King...
