What viscosity driveline oils does a 9g champion tractor use .
   / What viscosity driveline oils does a 9g champion tractor use . #1
niteclubrex
Champion 9G 1975
   / What viscosity driveline oils does a 9g champion tractor use . #2
I'd run 15W-40 if it were mine. 10W-30 if you’re in colder temps. Either way, she’ll be fine. Just double-check the manual if you’ve got one.
   / What viscosity driveline oils does a 9g champion tractor use . #3
Welcome to this forum. by "driveline oils" assume you mean engine oil, or gear/hyd oils as well? can't help on ladder, but yes, 15/40 should be fine. i prefer 5/40 full syn in colder climate starts. Rotella comes to mind. might be helpful to mention your location on the subject, regards
   / What viscosity driveline oils does a 9g champion tractor use . #4
Start with the Owners manual/dealer recommendations and then consider your location in the world to assist with your decision….
   / What viscosity driveline oils does a 9g champion tractor use . #5
OP: have you gone to the manu website to inquire if you don't have that owners manual? is the machine still in production? how many hrs on machine? do you know history of engine oil (or other fluids) maintenance? that may help make an informed decision
Thanks Linda
UNUSED FUTURE FT-RT57 57" HYD ROTARY TILLER (A51248)
UNUSED FUTURE...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A53426)
2002 MANAC 48'...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
UNUSED X-STAR 8' X 40' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 8' X...
