What viscosity driveline oils does a 9g champion tractor use .
   / What viscosity driveline oils does a 9g champion tractor use . #1
niteclubrex
Champion 9G 1975
   / What viscosity driveline oils does a 9g champion tractor use . #2
I'd run 15W-40 if it were mine. 10W-30 if you’re in colder temps. Either way, she’ll be fine. Just double-check the manual if you’ve got one.
   / What viscosity driveline oils does a 9g champion tractor use . #3
Welcome to this forum. by "driveline oils" assume you mean engine oil, or gear/hyd oils as well? can't help on ladder, but yes, 15/40 should be fine. i prefer 5/40 full syn in colder climate starts. Rotella comes to mind. might be helpful to mention your location on the subject, regards
   / What viscosity driveline oils does a 9g champion tractor use . #4
Start with the Owners manual/dealer recommendations and then consider your location in the world to assist with your decision….
   / What viscosity driveline oils does a 9g champion tractor use . #5
OP: have you gone to the manu website to inquire if you don't have that owners manual? is the machine still in production? how many hrs on machine? do you know history of engine oil (or other fluids) maintenance? that may help make an informed decision
Thanks Linda
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
1831 (A51247)
1831 (A51247)
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
CONTACT INFO (A53084)
2025 KMR 40in Single Cylinder Grapple Skid Steer Attachment (A51691)
2025 KMR 40in...
2018 TAKEUCHI TL12V2 SKID STEER (A51246)
2018 TAKEUCHI...
