What viscosity driveline oils does a 9g champion tractor use .
   / What viscosity driveline oils does a 9g champion tractor use . #1
niteclubrex
Champion 9G 1975
   / What viscosity driveline oils does a 9g champion tractor use . #2
I'd run 15W-40 if it were mine. 10W-30 if you’re in colder temps. Either way, she’ll be fine. Just double-check the manual if you’ve got one.
   / What viscosity driveline oils does a 9g champion tractor use . #3
Welcome to this forum. by "driveline oils" assume you mean engine oil, or gear/hyd oils as well? can't help on ladder, but yes, 15/40 should be fine. i prefer 5/40 full syn in colder climate starts. Rotella comes to mind. might be helpful to mention your location on the subject, regards
   / What viscosity driveline oils does a 9g champion tractor use . #4
Start with the Owners manual/dealer recommendations and then consider your location in the world to assist with your decision….
   / What viscosity driveline oils does a 9g champion tractor use . #5
OP: have you gone to the manu website to inquire if you don't have that owners manual? is the machine still in production? how many hrs on machine? do you know history of engine oil (or other fluids) maintenance? that may help make an informed decision
Thanks Linda
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
Unused Delta Crash...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2007 INTERNATIONAL SF625 BUCKET TRUCK (A50854)
2007 INTERNATIONAL...
