What type steel to use in FEL rebuild?
   / What type steel to use in FEL rebuild? #11
I think A36 plate for the bucket and 1018 mild steel for wear strips should be fine. If the 1018 starts wearing down, caught in time, it's easy enough to replace with a new strips.
   / What type steel to use in FEL rebuild? #12
If only used in dirt its fine. When ised to push snow off asphalt, or scoop manure from a concrete bunk, mild steel disappears as snow before the sun.
   / What type steel to use in FEL rebuild? #13
I built my own bucket for plowing snow. 50 percent wider and also a little taller to speed up the process. It's only been used to plow snow on a gravel drive but shows no wear after two full seasons. I used 11ga. mild steel for the bucket and 3/8 x 3 mild steel for the cutting bar after being unable to source anything else economically. No wear bars or hard surfacing and I'm happy with the results.
   / What type steel to use in FEL rebuild? #14
I agree. The type of usage and surface hardness might dictate some tougher steel.
2007 Ford F-150 (A55973)
2007 Ford F-150...
2012 FORD F-550 SUPER DUTY CAB AND CHASSIS (A58214)
2012 FORD F-550...
John Deere 3025E (A53317)
John Deere 3025E...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
