What type steel to use in FEL rebuild?
   / What type steel to use in FEL rebuild? #11
I think A36 plate for the bucket and 1018 mild steel for wear strips should be fine. If the 1018 starts wearing down, caught in time, it's easy enough to replace with a new strips.
   / What type steel to use in FEL rebuild? #12
If only used in dirt its fine. When ised to push snow off asphalt, or scoop manure from a concrete bunk, mild steel disappears as snow before the sun.
   / What type steel to use in FEL rebuild? #13
I built my own bucket for plowing snow. 50 percent wider and also a little taller to speed up the process. It's only been used to plow snow on a gravel drive but shows no wear after two full seasons. I used 11ga. mild steel for the bucket and 3/8 x 3 mild steel for the cutting bar after being unable to source anything else economically. No wear bars or hard surfacing and I'm happy with the results.
   / What type steel to use in FEL rebuild? #14
I agree. The type of usage and surface hardness might dictate some tougher steel.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2006 International 9400i (A55302)
2006 International...
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2008 Ford F-150 Ext. Cab Pickup Truck (A56858)
2008 Ford F-150...
