what type of oil?
/ what type of oil? #1
Ty Parent
ware , ma.
ford 8n
Hey guys I have a 1948 ford 8 n. Does any one know what type of motor oil to use? It is a 4 cylynder gas. I believe it should be 20w nondetergent
/ what type of oil? #2
If it were mine I'd probably be running a quality conventional 10w40 High Mileage, unless the engine has been recently rebuilt, then skip the
HM. Non detergent oils allow gunk to build up instead of being removed when you change oil. Oils have been vastly improved since your tractor was built. why not take advantage of that.
/ what type of oil?
I was told by my local Napa that non detergent is the way to go. I think that's a bunch of crap,but asked you guys as a second opinion. Thanks.
/ what type of oil? #6
I'd do a bit more research before feeling comfortable using a 20W oil in a 60+ year old loosey-goosey engine. Modern engines can use a multi-viscosity or straight 20W oil because they are made to run those oils with nice & tight engine tolerences. Your 64 year old Ford, not so much! That's why I initially recommended a 10w40 HM oil. At operating temperature it's a 40W oil and the HM will have seal conditioners to help keep those old seals a bit softer.
/ what type of oil? #7
A modern 15W40 or maybe 10W30 Diesel rated oil will have the additive package and viscosity that an old 8N can benefit from as compared to a modern day S- rated gas engine only motor oil. If you want to use a single viscosity oil I 'd use nothing less than 30W and certainly NOT a non-detergent of any type.
/ what type of oil? #8
I agree. I run 15w40 ( temp range=florida) C(S) rated oil in all my machines except 1, and that one has had synthetic in it since some top end work.
Im my powerstrokes I run 5w40 syn.
the ND oil recomendation from the napa guy is a load of bull ... we've moved on from 1948
soundguy
Western 8.5 Pro Plus Ultra Mount (A62679)
Western 8.5 Pro...
2022 EZ-GO ELITE...
Case IH 950 Planter (A63688)
Case IH 950...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
