What type of oil for finish mower gearbox?
   / What type of oil for finish mower gearbox? #1
2kpsd
Martell, NE
Montana Limited 300DTC
Newbie question - what type of oil do I need to put in a king kutter rfm? I just bought a 5' used mower from my neighbor and I'm not sure what I need to use to top it off and make sure it is ok before I use the mower.
   / What type of oil for finish mower gearbox? #2
Gear oil you can pick up at W*M or any auto parts store. The manufacturer may have a specific recommendation, but I use 80W90.
   / What type of oil for finish mower gearbox? #3
Just for the heck of it.. check the manual.. however.. I wouldn't be afraid of anything like 80w90, 90wt, or 85/140.
You do realize that you can download the manual in PDF format from KK for free.
( FWIW.. my KK mower manual states to use SAE 80w90 or 85/140 gearbox lube.. and grade II tube grease for the grease fittings.. )
Here is the link to your finish mower manual:
http://www.kingkutter.com/downloads/manFMSD.pdf
If it is a rear discharge finish mower:
http://www.kingkutter.com/downloads/manFMRD.pdf
Hope this helps.. Good luck
Soundguy
Soundguy - yes, that does help me. I appreciate it -
   / What type of oil for finish mower gearbox? #5
I suppose if you wanted to get all fancy you could go with synthetic gear lube---Napa has some Valvoline and Mobil 1, probably one quart would be more than enough
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
1995 Western Star 4900 T/A Wrecker Tow Truck (A53422)
1995 Western Star...
2023 G Bar K Skirted Hauler Bed (A55218)
2023 G Bar K...
