What type of oil for finish mower gearbox?
   / What type of oil for finish mower gearbox? #1
2kpsd
Martell, NE
Montana Limited 300DTC
Newbie question - what type of oil do I need to put in a king kutter rfm? I just bought a 5' used mower from my neighbor and I'm not sure what I need to use to top it off and make sure it is ok before I use the mower.
   / What type of oil for finish mower gearbox? #2
Gear oil you can pick up at W*M or any auto parts store. The manufacturer may have a specific recommendation, but I use 80W90.
   / What type of oil for finish mower gearbox? #3
Just for the heck of it.. check the manual.. however.. I wouldn't be afraid of anything like 80w90, 90wt, or 85/140.
You do realize that you can download the manual in PDF format from KK for free.
( FWIW.. my KK mower manual states to use SAE 80w90 or 85/140 gearbox lube.. and grade II tube grease for the grease fittings.. )
Here is the link to your finish mower manual:
http://www.kingkutter.com/downloads/manFMSD.pdf
If it is a rear discharge finish mower:
http://www.kingkutter.com/downloads/manFMRD.pdf
Hope this helps.. Good luck
Soundguy
Soundguy - yes, that does help me. I appreciate it -
   / What type of oil for finish mower gearbox? #5
I suppose if you wanted to get all fancy you could go with synthetic gear lube---Napa has some Valvoline and Mobil 1, probably one quart would be more than enough
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
1065 (A53342)
1065 (A53342)
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
