ducks13
- Joined
- Oct 3, 2010
- Messages
- 129
- Location
- Charlotte, NC
- Tractor
- JD 4410, two JD 318's, 50" and 46" MMM, 48" KK BB
Hi, I need some help deciding what tractors will fill my needs and what I particularly need to look for.
I have couple of acres that is heavily wooded with some open areas. I really want to have a continuing landscaping project and think I deserve a tractor with a loader. On my property there are some steep grades, 40 to 50% in places that I think I壇 like to be able to go up while using the box blade on turf tires. I may also want to use the tractor to move a 20 enclosed trailer that will weigh about 4,000 to 5,000 ibs using the 3 pt. Part of the path I will need to take the trailer up and down has about a 20% grade. I will be using the loader primarily for moving compost, mulch and dirt as well as lifting fallen trees and such.
I already have a JD 318 garden tractor with a 3 point on it. I have a 48 deck for it, a 48 King Kutter box blade, a 30 hydraulic tiller, a 48 aerator and a 10 cu. Ft. poly cart. Actually I have two 318 but one has a broken rod and I haven稚 found time to fix it yet.
I think I will need 4WD with diff lock to do this and I particularly want the tractor to have a ROPS for safty痴 sake. Ideally it would have two rear remotes so I could get a hydraulic cylinders for the top link and one of the side links on the 3 pt for use with a box blade. If I could easily just remove the loader and use those two SCV痴.
I may also want to use the tractor to move a 20 enclosed trailer that will weigh about 4,000 to 5,000 ibs using the 3 pt. Part of the path I will need to take the trailer down and up has about a 20% gravel grade. How big a tractor will I need (weight and 2 wheel of 4 wheel drive) to do this safely?
I壇 like to spend no more than about 10K on this unit. I have excellent mechanical repair skills so an older tractor would be OK. I am thinking that a 655 of 755 would work well and I致e also thought about a 2210. Any others that I should be looking for? What JD or other manufacturers units should I be looking for to accomplish the above?
Thanks for any input
John
John
