Tractor Sizing What tractor to buy?
   / What tractor to buy? #21
The plow is nice but that is a lot of money for a lawn mower sized tractor with not so great parts support.
I would really consider a 8N. Tons of them, cheap, and can do a lot of work.
Where are you located? I know where there is a Cub Low Boy and a Jinma 284 with a Loader for the cheap.
Chris
Just my opinion, but Kubota, John Deere, etc equals parts availability. Some of the others, like an older Bolens, are getting difficult to locate parts. Keep that in mind. You are going to find a ton of tractors for sale in that $3-4000 range. You have to actually go see them, drive them, talk to the owner and make a decision. No one can say from behind a computer screen if any particular machine is "good" or "bad" other than generalizations based on history, parts availability, or general reputation.
Yeah, the parts availability scares me on something that's been out of production so long. It was in really great shape and drove perfectly so I thought it might be worth it. My buddy was convinced it was worth no more than approx. $2200 so I passed. Since the mid atlantic was hit so hard with snow it seems anything with a blade was for sale or for sale at an inflated price.
Chris
I like the 8n. I'm just concerned about the weight on a lawn with a 3 point mower behind it. The ground is realtively soft here and my pickup has already massacred much of the yard behind the house.
Located in MD.
   / What tractor to buy? #24
Yeah, I care mostly about how the machine was treated over age and hours.
A knowledgable friend came with me to look at a Bolens, but said it was way overpriced. What do you think of this one?
"Bolens/Iseki G152 water cooled 3 cylinder 15 hp diesel. Transmission has 3 forward/1 reverse with high/low range. Locking differential , cat 1 3 point hitch , 3 speed pto , 4 hydraulic outlets on the front that can easily be rerouted to the back for attachments if needed. Hoses are all in good condition with no leaks. 54" hydraulic lift/angle blade and 50" belly mower both in very good condition and ready to use. Also has wheel weights and working headlights. Tires have good tread with no leaks. Tractor has plenty of power and loads of low rpm torque. Engine starts easily (even in cold temps) runs smooth and performs flawlessly. Overall in excellent condition and has always been reliable. Asking $3150"
That seems to fit right into what you are looking for...they are very good, versatile machines and would be a great fit for your intended use. Any bargaining room on the price would make it an even better fit ($3K).
   / What tractor to buy? #25
P.S. Joey...Bolens parts are not that hard to find...Jack's Small Engines can get pretty much anything you would need for the Bolens...If it is as good as you described, it's definitely worth consideration...just don't expect to find parts readily available locally...have to go the order online and wait route.
   / What tractor to buy? #26
Try sheafstractor@grics.net. He says he can get any part (including manuals) within a couple of days...I think that particular model has an Iseki (Japenese) engine...they have a pretty good track record. It's the same brand of engine used in the current MF GC series.
   / What tractor to buy? #27
Neat looking little tractor. Looks similar to my Bolens GT1453 that has a 14 hp Tecumseh gas engine.
I found this one on craigslist for $600 including a 42" mid-mount mower and the 32" wide rototiller. Maybe you could find a similar rototiller to fit that G152.
The asking price is within your budget. You may be able to haggle the price down a little to say $3K.
   / What tractor to buy? #28
I saw that Bolens too on CL. Seems nice. But, I also thin it's a little high. You can find a JD 400 series similarly equipped for about that kind of money, and I think it would be a better buy. Now if you could get him to say $2500 or so, then it might make some sense.
There are a couple of nice 455's right now on ebay, worth checking out.
At $4K, you will be limited to quality GTs or a much older tractor. However, the GT's won't have the weight nor hydraulics to do any heavy lifting/towing.
Did you see the Kubota with a broken drive shaft for $2700 on CL? Might be a better choice. Just have to understand how much work and money is involved with the broken drive shaft.
Just remember if you want a loader later on, they aren't so easy to find used, and aren't a whole lot cheaper than new when you do. Another word of caution: the JD 400 series with AWS option cannot be fitted with a loader.
   / What tractor to buy? #29
Welcome to TBN. I bought my 1st tractor at an auction, with spring coming (I hope), you will start to see more auctions around. As someone else recommended, Jacks small engines is good for parts for garden tractors, etc. They are located in MD but I order on the web from them.
   / What tractor to buy? #30
If you are limited to a $4000 dollar budget I think you are better off buying a good lawn mower like the Deere X324 AWS. Start working away from the house cleaning up areas as you go. Don't abuse the mower but get a cart to pull behind it When you get a large area cleaned and cleared check on renting a tractor and tiller for the weekend. If you can work steadily and are retired then rent a 40 hp tractor and equipment for a week or month to get the place ready to seed the lawn and clean up the wooded area. In a matter of weeks you should be able to get most of the heavy work done leaving you with mostly mower work.
My reasoning for the above is that the implements alone will cost quite alot of money, simply buying a tractor is only the beginning. I have had plenty of older tractors and equipment and still have some of it but parts can be expensive and hard to find, truth is if you are still busy working to feed a family it may cost you more time with old equipment than it is worth.
To sum it up I recomend buying one good piece of equipment at a time, buy it once and buy it right.
   / What tractor to buy? #31
I've got 5 acres that are a bit more woods than grass, and I haven't been able to move out there yet due to the economy-but enough about me. I've been thinking about this awhile myself. So far, I've got a DR mower to keep the weeds and grass at bay. My next step, eventually, I'm thinking Kioti CK20 or something else in the under 25hp size. No loader for now, I can add that later. .
If you buy a loader with the tractor you will get a much better price. There are often "free loader" deals. If you add one later you'll pay full freight which can be $2500-3500.
I had a CK20 to clean up and clear about 5 acres. Awesome little tractor for that type of work. Much more capable than any SCUT. Add a grapple and bush hog and you can clear most anything. A used low hour CK20 with loader can be had for $10-13K. Tremendous value.
   / What tractor to buy? #32
Thanks, I didn't think about the shipping. I'll have to see what's available in the used market when I go shopping.
UNUSED FUTURE FT15P EXCAVATOR (A60430)
UNUSED FUTURE...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
405 (A52706)
405 (A52706)
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
LIGHT TOWER (A56857)
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
