What to expect from a mulcher on a svl75 standard flow.
   / What to expect from a mulcher on a svl75 standard flow. #11
After the original blades would wear out, I wonder how hooking up chains would work on a CTL bushhog mower ? Like the TBN member here from Portugal (can't remember his handle) with a Branson tractor has posted videos of tractors with three point of course rear mounted bushhogs. Might be a way cheaper alternative from buying replacement blades ? Not saying it is just some thoughts .
   / What to expect from a mulcher on a svl75 standard flow. #12
I think you’d only be able to cut light brush like that. I can’t see chains cutting 4 inch or larger trees.
   / What to expect from a mulcher on a svl75 standard flow. #13
Do those work as good as the drum ones?
Much faster but not as small chips and throws them wildly, BUT I've never run either a only have a YouTube education on the matter 😄 along with other forums and some folks that are in the business. Apparently bigger mulching contractors will run both types, knocking it down quickly with the disc and if required, running the drum style across it for a more constant and finer finish.
There's quite a bit on YouTube if you search disc mulcher, even the outdoor Morgan guy has a video.
   / What to expect from a mulcher on a svl75 standard flow. #14
Yet they do, even thicker stuff with bigger setups. Matter of fact, we don't even use skidsteers with mulching heads for clearing brush. Just a tractor with either a PTO mulching head or one of these brush mowers with chains that operates faster and at a third of the cost of a skidsteer while still producing very nice results. I'll go as far as saying that a 70 HP tractor will outwork a 95HP skidsteer.
In certain scenarios, the chains will actually work much better than blades or a mulching head. The biggest advantage is that chains don't care about rocks, stumps or whatever it's hidden in the brush.
I've done up to 3" easily with my little 35 HP tractor.
A couple pictures of my mower, which is a light duty one. The heavy duty and forestry versions are some bada$$ units made mostly out of Hardox steel and can/will eat some really nasty stuff.
A couple of examples a brush mower with chains:
   / What to expect from a mulcher on a svl75 standard flow. #15
View attachment 734433 View attachment 734434
A tractor no doubt cuts grass cheaper than than a skid steer but I don’t agree with 1/3 the cost. In heavy brush the skid steer shines. The skid steer comes from the factory sufficiently armored for the job. A tractor needs extensive plating to be ready for the job and probably won’t ever have equally as good protection for the operator. Also the skid steer has superior maneuverability and you’re facing your mower which is going to be better and less fatiguing. The tractor would no doubt win at mowing a field but when you’re in heavy brush especially with larger trees you can’t mow the skid steer is winning that one. The main advantage a tractor has over the skid steer is speed and the ability to run a much wider batwing mower. But when you’re in heavy growth you’ve lost both of those advantages and you’re back to driving backwards and the skid steer guy is facing his work.
   / What to expect from a mulcher on a svl75 standard flow. #17
I would hate to know that I had to look backwards all day, but it was getting the job done.
   / What to expect from a mulcher on a svl75 standard flow. #19
Did you bother to watch the videos? These mowers are used in heavy brush, exactly where they shine. A skidsteer spends more time ramping the mower speed up, only to slow down again on the next hit again.
We're used to operate the tractors in tight spaces so we probably work around it just fine. If there is an area that's big enough to be a field, then it's either a pasture or used to grow something. So it's not that people here is mowing huge fields either.
A fully shielded tractor with forestry tires and a heavy duty brush mower with two rotors with 4 chains per rotor will be quite a bit cheaper than a skidsteer with a brush mower, plus it can move in between jobs without an extra hauling equipment, while still operating at a third or less of a cost of the skidsteer. A 75HP tractor mowing brush here, will cost about $75 to $100/hour. What would a skidsteer cost? $350/hour if I remember correctly from a couple threads here? And would take more time than the tractor to do the same job.
If the skidsteer would be that much superior, trust me, we would be all over it in my country because we do value our hard earned money very well, yet the skidsteers seem to stay in the construction business.
As far as looking backwards, you'll look backwards quite a bit on a skidsteer as well, unless you like hitting whatever it's behind you. Part of operating a tractor, is actually looking backwards. Not sure why this is a big deal. We seem to survive just fine over here.
Two rotors on this one to reduce the overall length of it:
   / What to expect from a mulcher on a svl75 standard flow. #20
i ordered my skidsteer with a backup camera and on my farm tractors I use mirrors where possible, it's only a big deal because it hurts my neck to look backwards for long periods of time now that I am older, we survive pretty good over here ourselves.
Boat (A59231)
Boat (A59231)
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
Deere 331G (A53317)
Deere 331G (A53317)
8065 (A55852)
8065 (A55852)
Deere 335P (A53317)
Deere 335P (A53317)
3410 (A47477)
3410 (A47477)
