What to do with old Bush hog gearbox?
   / What to do with old Bush hog gearbox? #1
Brahmus
South Louisiana
I have an old 6' bush hog that's had the deck completely rotted out. The gearbox is good, but I don't know what I could use it for. Any suggestions?
   / What to do with old Bush hog gearbox? #2
Re-build the deck out of some sheet metal and still have a bush hog.
Turn the gear box sideways and run a buzz-saw (AKA man-killer) with it.
Turn it upside down and make a broadcast spreader that will spread fertilizer far and wide in a single pass.
Reverse the box by connecting the tractor PTO to the output and make a cement mixer.
As a final boring suggestion, you could just put it up on E-bay and get a few bucks out of it.
   / What to do with old Bush hog gearbox? #3
Why not make yourself a big old trencher out of that gearbox. All you would need is a shaft going out to the side. Add some pillow block bearings and a trencher blade, and you are set. You should build a housing for the trencher blade.
You could also build a post hole digger.
   / What to do with old Bush hog gearbox? #4
First buy yourself a new bushhog and then
Offer the gear box to some TBN-er that might need it, for a fair price.
You will be happy with a new hog and some poor sap will be happy to be able to fix their olde hog.
By the way mine is in very good shape and I don't need a gearbox!
   / What to do with old Bush hog gearbox? #5
That would be one fast spinning post hole digger.........
Already have a new hog!
Would it spin that fast at idle?
I could use a trencher or a post hold digger. I'm not envisioning the Trencher though....
   / What to do with old Bush hog gearbox? #7
Ive got 2 trenchers made from old gear boxes. they work wonders. Make sure the sheils is all the way around most of it.
   / What to do with old Bush hog gearbox? #9
I am fixing to trade a 6' bush hog for a finish mower, and really wish you lived closer, because I would love to have one that I could rebuild the deck on, to replace the bush hog I am fixing to get rid of. I need a bush hog, but the finish mower has a paying job coming with it, so I figure I better take it...
David from jax
   / What to do with old Bush hog gearbox? #10
What is the gear ratio of a bush-hog gearbox? It could be 1:1, or 1;2, or maybe 1:3
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
CAT930K (A58214)
CAT930K (A58214)
