Buying Advice What to buy and what's in the HP numbers?
   / What to buy and what's in the HP numbers?
The phone app will only let me upload one picture at a time, so unfortunately I had to do multiple posts.
I now have rear chains on as well.
Trygg SMT95
Front Chains came but they are too big. They rub on the driveline on the axle.
I suspect that they would be better suited to a wider tire (Industrial) but the narrow Ag tires seem to play havoc with the fitment. I don't think it helps that the dealer supplied 8.3x16 chains (tires are 8x16)
They are supposed to be Trygg too, but they don't exactly match my back chains in visual construction or in the matter in which they were packaged.
Dealer is supposed to check on some options and get back to me.
   / What to buy and what's in the HP numbers? #62
Looks like a very nice setup. Did you get your rear tires loaded?
Thank you enjoying it so far. Nice to be in the cab out of the weather.
Hauling home the firewood today and I put a lot extra on the wagon. RPM never moved on the downgrades. ( maybe 3/4 cord split and packed) and didn't use the brakes.
My only concern so far is the volume of fuel I am using in comparison to my MF35. This new rig is thirsty.
   / What to buy and what's in the HP numbers? #65
I don't know about that model Massey"s engine but as a rule the larger the tractor the more work gets done per gallon of fuel used. It may use twice the fuel per hour but should do more then twice the work in that same hour. Of course sitting idling while you take pictures doesn't give you any work done to pay for the fuel. ;)
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
New/Unused 13ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 13ft X...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
