what tires you guys running
   / what tires you guys running #11
The skid steer tires are overall very stiff. The trencher tire will have a little more side wall flex and should be similar or softer ride. Wider tire should be a bit softer. With the steering of the TC, trencher tires should last a very long time but with less overall rubber on the treads, not as long as a skid steer.
Here is a link to another company which has an 8 ply trencher tire to get the higher load ratings with a 29x1250-15 size. Rated for 3400 lbs, which is way more than enough.
GPX International Tire Corp.
I expect these high ply and less common trencher tires to be expensive!
The 29x12.5-15 trencher tire will fit on the TC 12.5" turf rims. If you are running 29x10.5-15 skid steer tires, then you will need new rims.
   / what tires you guys running #12
Pioneer
What was the rough price of those trencher tires?
   / what tires you guys running #13
Pioneer
Radman 1
Set of 4 ditch digger tires cost $650 installed. Also keep in mind that the trencher tires were the same ply (6) as the factory 29-12.5x15 turf tires that I took off. DO NOT try to put the 12.5 wide tire on the 10.5 skid steer or narrow turf rim as it will not work (I tried).
   / what tires you guys running #14
need help finding more info on turf tires for my toolcat, use for landscaping and snow removal I think the turf tire would be the best all around tire any help and info on the tires (brand specific) having trouble finding info and availability.
Jared
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
BED FROM 2024 FORD F250 SUPER DUTY (A57880)
BED FROM 2024 FORD...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A57880)
2019 KENWORTH T680...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
