what tires you guys running
   / what tires you guys running #11
The skid steer tires are overall very stiff. The trencher tire will have a little more side wall flex and should be similar or softer ride. Wider tire should be a bit softer. With the steering of the TC, trencher tires should last a very long time but with less overall rubber on the treads, not as long as a skid steer.
Here is a link to another company which has an 8 ply trencher tire to get the higher load ratings with a 29x1250-15 size. Rated for 3400 lbs, which is way more than enough.
GPX International Tire Corp.
I expect these high ply and less common trencher tires to be expensive!
The 29x12.5-15 trencher tire will fit on the TC 12.5" turf rims. If you are running 29x10.5-15 skid steer tires, then you will need new rims.
   / what tires you guys running #12
Pioneer
What was the rough price of those trencher tires?
   / what tires you guys running #13
Pioneer
Radman 1
Set of 4 ditch digger tires cost $650 installed. Also keep in mind that the trencher tires were the same ply (6) as the factory 29-12.5x15 turf tires that I took off. DO NOT try to put the 12.5 wide tire on the 10.5 skid steer or narrow turf rim as it will not work (I tried).
   / what tires you guys running #14
need help finding more info on turf tires for my toolcat, use for landscaping and snow removal I think the turf tire would be the best all around tire any help and info on the tires (brand specific) having trouble finding info and availability.
Thanks
Jared
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56436)
2023 Kubota...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
PALLET TOTE OF JARS & MISC (A58374)
PALLET TOTE OF...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
AUCTION STARTS HERE @ 9AM (A52708)
AUCTION STARTS...
2020 Bobcat T595 (A57148)
2020 Bobcat T595...
