What things are important on a new tractor?
   / What things are important on a new tractor? #21
wvtechs said:
Does welding a reinforcement bar (angle iron) across the top of the bucket and adding chain hooks affect the manufacturers warranty? I am ordering a new Mahindra 3215 and am interested in adding them, but don't want to void the warranty.
In my case, I supplied the hooks and the dealer welded them onto the bucket. Did the same thing three years ago when I bought a new Kubota B7510HST/LA302 FEL. No effect on warranty in either case.
   / What things are important on a new tractor? #22
Your situation is very similiar to mine. 25ac mostly flat. Pasture grows rocks constantly. And I'm redoing the driveway. I did a lot of research before hand and also looked at what my budget would allow. I settled on a JD 5103 (40pto hp), 512 loader with a 73" bucket, 6ft rotory mower and a 6ft box blade. So far I'm not unhappy at all with my selection. Other things mentioned are niceaties and I can always add them later if I need them. BTW I'm in central Texas so weather is similiar in many ways.
Projects in the works;
Crown and finish drive.
Build stock pond.
Build new barn.
Clear cedar from pasture.
And many many more.
   / What things are important on a new tractor? #23
KevinPeter said:
The "how important" list:
- Rear hydraulic remotes? AT LEAST ONE SET, TWO BETTER
- Cruise Control? PLUS/MINUS UNLESS YOU MOW A LOT
- Reinforcing blade on the FEL? SAVES BUCKET LIFE BUT NOT CRITICAL
- Self-leveling on the loader? NOT THAT USEFUL UNLESS YOU LIFT DIRT/GRAVEL HIGH A LOT
- Cab? FOR EXTREME TEMPERATURES VERY NICE OTHERWISE NOT IMPORTANT
- 6' or bigger cutter? 6FT OK FOR 40HP. BIGGER FASTER BUT UNWEILDY
- Welded-on chain hooks onto bucket - center & each end? USEFUL
- Extendable rear 3pt arms vs. fixed? EXTENDABLE EASIER TO ATTACH
The "what is it and how important" list:
- Cast wheel centers? NOT
- Additional functions on the front loader - what possible? EXTRA HYDRAULIC VALVE OR DIVERTER TO ALLOW GRAPPLE OR 4N1 FUNCTION IS VERY USEFUL
- Rear Tires loaded w/ Rimguard? OR WINDSHIELD WASHER FLUID
- Shuttle type?
- Live power PTO? YES
Thanks for your help. I appreciate it so much.
Kevin
Lots of good questions. My opinions in caps.
(Edit: Dang, caught answering a six month old thread again.:eek: Wish TBN has some sort of warning system to keep us from doing this)
bad boy zero turn 72 (A56859)
bad boy zero turn...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
Pickup Truck (A59230)
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
