What thickness angle iron to weld hooks on bucket?
   / What thickness angle iron to weld hooks on bucket?
   / What thickness angle iron to weld hooks on bucket? #12
For my littler tractor I used 4x4x1/4 and cut most of one leg off. I laid the short leg over the front and the long leg across the top. I used metal I cut off the one leg to cut supports for the sides. I cut one eye off some Harbor Freight 3/8" forged hooks and welded them on. I have lifted the full capacity of my loader which is about 1200+ lbs. with no problem.
The bushing legs on my backhoe's loader are 3/8 and I imagine they are made from high strength steel. It's lift capacity is right at 7000 lbs.
That looks really sturdy, thanks for the input!
   / What thickness angle iron to weld hooks on bucket? #14
I used 3"x3"x3/8" angle on my 3930....No problems
   / What thickness angle iron to weld hooks on bucket? #16
2 x 2 x 3/8 full width with 3/8" plate on the sides.
3900lbs lift capacity to full height
Zero bends in 15 years.
Brian, difficult to see detail on your bucket teeth.
Are they custom, individually welded on, bolted on - or is it a commercial tooth bar add on?
Interested...
   / What thickness angle iron to weld hooks on bucket? #17
Zero bends in 15 years. :thumbsup:
Rugged looking bucket!
   / What thickness angle iron to weld hooks on bucket? #18
Interested...
It is a 78" bucket with individual welded on mounts and pinned teeth. I have an 84" bucket with smooth cutting lip for moving loose material.
   / What thickness angle iron to weld hooks on bucket? #19
Thanks for that...it looks strong!
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
LOT: (9) Wheel Loader Shanks (A59076)
LOT: (9) Wheel...
72in Forklift Safety Basket (A56857)
72in Forklift...
60in Forks (A56857)
60in Forks (A56857)
