What thickness angle iron to weld hooks on bucket?
   / What thickness angle iron to weld hooks on bucket?
   / What thickness angle iron to weld hooks on bucket? #12
For my littler tractor I used 4x4x1/4 and cut most of one leg off. I laid the short leg over the front and the long leg across the top. I used metal I cut off the one leg to cut supports for the sides. I cut one eye off some Harbor Freight 3/8" forged hooks and welded them on. I have lifted the full capacity of my loader which is about 1200+ lbs. with no problem.
The bushing legs on my backhoe's loader are 3/8 and I imagine they are made from high strength steel. It's lift capacity is right at 7000 lbs.
That looks really sturdy, thanks for the input!
   / What thickness angle iron to weld hooks on bucket? #14
I used 3"x3"x3/8" angle on my 3930....No problems
   / What thickness angle iron to weld hooks on bucket? #16
2 x 2 x 3/8 full width with 3/8" plate on the sides.
3900lbs lift capacity to full height
Zero bends in 15 years.
Brian, difficult to see detail on your bucket teeth.
Are they custom, individually welded on, bolted on - or is it a commercial tooth bar add on?
Interested...
   / What thickness angle iron to weld hooks on bucket? #17
Zero bends in 15 years. :thumbsup:
Rugged looking bucket!
   / What thickness angle iron to weld hooks on bucket? #18
Interested...
It is a 78" bucket with individual welded on mounts and pinned teeth. I have an 84" bucket with smooth cutting lip for moving loose material.
   / What thickness angle iron to weld hooks on bucket? #19
Thanks for that...it looks strong!
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
