What spray lube do you like?
   / What spray lube do you like? #21
PB Blaster for stuck things. A variety of spray lubes depending on the application including white lithium and LPS. I use WD40 occasionally but most often as a cleaning solvent for gunk (or carb cleaner or brake cleaner depending). It is supposedly one of the best lube for machining aluminum, but I haven't had the need.
   / What spray lube do you like? #23
Slick 50 works great
   / What spray lube do you like? #24
No, Krown.
I have my vehicles sprayed with it for rust control and no bolts are ever seized on them.
Plus you can get different formulations in can. For rust prevention, penetrating oil, safe on electronics, etc.
We get 6 months of salt and de-icing chemicals on the roads here and it has proven itself to me.
How much is the Krown spray in Soo ? We bought a new Jeep and thought I might try a rust spray place this fall. Do they drill or use existing holes ?
   / What spray lube do you like? #26
I can't remember exactly, but I get that salt elimintor wash before the oil spray and I think it is around $150 for a truck or SUV.
They drill some holes where needed. But they've always done a nice neat job.
   / What spray lube do you like? #27
   / What spray lube do you like? #28
White lithium and fluid film
wd 40 now and then, more of a habit I guess
   / What spray lube do you like? #29
It depends on what I'm using it for and how close it is at hand. I've had good results with
PB Blaster (primarily loosening stuck fasteners)
Kroil (all around)
Corrosion X
T-9 Boeshield
Fluid Film (primarily as a protectant)
I don't use WD40 as a lubricant, I do use it for cleaning, degreasing type tasks
   / What spray lube do you like? #30
The Project Farm guy did a video on this for YouTube. The results were pretty interesting as I recall, but I don't remember which product was the winner.
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2014 Ford F-150 Pickup Truck (A55973)
2014 Ford F-150...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
TORO SAND PRO 3020 (A58374)
TORO SAND PRO 3020...
Deere 325G (A57148)
Deere 325G (A57148)
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
