What spray lube do you like?
   / What spray lube do you like? #11
I have to admit that I have some WD-40. It was given to me, so I use it on the band saw blade.
For freeing up rusted things, I think it's next to useless. Especially when compared to a 50/50 mix of acetone and ATF.
For normal daily use it's generally JB-80, aka Twice as Good. Which compared to WD-40 isn't saying much.
   / What spray lube do you like? #12
Liquid Wrench White Lithium Grease for anything that doesn't have a zerk. Mostly use WD40 to clean with, not really for lubrication.
   / What spray lube do you like? #13
LPS #1 (like WD40), LSP #2 (light lubricant) and LSP #3 (heavy thicker protectant and lube for stuff left out in the elements). LSP products are good stuff. Been using it for years.
   / What spray lube do you like? #14
PB Blaster for most general things but Kroil if I need heavy duty penetration. Got hard to find Kroil locally so now I just order from Amazon.
   / What spray lube do you like? #15
No, Krown.
I have my vehicles sprayed with it for rust control and no bolts are ever seized on them.
Plus you can get different formulations in can. For rust prevention, penetrating oil, safe on electronics, etc.
We get 6 months of salt and de-icing chemicals on the roads here and it has proven itself to me.
   / What spray lube do you like? #16
PB blaster is my go to. Kroil is better but it’s expensive.
   / What spray lube do you like? #17
I use a lanoline based spray lubricant for darn near everything... if it moves, but doesn't have a grease nipple, it gets a 'shot' of "LANOX MX4" (Aussie product).
I do use a silicon spray for household hinges and along the top of curtain rods.
WD40 has it places.
   / What spray lube do you like? #19
CorrosionX when others fail. Anything besides WD40 for everything else.
   / What spray lube do you like? #20
Also, when I posted earlier, I should’ve mentioned the reason I do not like WD-40 is because it makes me nauseous, one of the few things in my life that really makes me feel ill other than gross bodily crap
Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
Sterling T/A Ox...
telescope boom (A56857)
telescope boom...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2018 JLG 600S TELESCOPIC BOOM LIFT (A52709)
2018 JLG 600S...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
2021 PETERBILT 579 DAY CAB (A58018)
2021 PETERBILT 579...
