what speed do i run a 4ft finish mower
   / what speed do i run a 4ft finish mower #1
traderman55
northeast mississippi
mitsubishi mt372
i have a 4 ft finish mower with my mt 372 ... what engine rpm ,, pto gear ,,an transmission speed do i run it .i do not want to damage my mower or my tractor ....thanks
   / what speed do i run a 4ft finish mower #2
It seems that 540 pto speed and pto speed should match up on the tachometer? You will know when you are mowing too fast, the mower will start streaking and lugging the tractor down. Ken Sweet
   / what speed do i run a 4ft finish mower #3
I ran mine at the 540 RPM (PTO) and in first gear. It feels slow, it is, but probably the best speed.
It would depend a lot on how rough the ground is, how familiar you are with the area, how thick the grass/weeds/trees are.
Go slow, be carefull !!
   / what speed do i run a 4ft finish mower #4
Many tractors have two PTO speeds, 540 and 1000 rpm. Many of the finish mowers will be running at 1000rpm.
As for ground speed that is determined by the height , thickness and type of grass plus the quality of cut you wish to achieve.
It's sorta an empirical experiment to find out what suits your needs.:D
   / what speed do i run a 4ft finish mower #5
Never ran a finish mower on my Satoh... the Woods RM42 mentioned using 2nd speed.
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
2239 (A51244)
2239 (A51244)
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
