what speed do i run a 4ft finish mower
   / what speed do i run a 4ft finish mower #1
traderman55
northeast mississippi
mitsubishi mt372
i have a 4 ft finish mower with my mt 372 ... what engine rpm ,, pto gear ,,an transmission speed do i run it .i do not want to damage my mower or my tractor ....thanks
   / what speed do i run a 4ft finish mower #2
It seems that 540 pto speed and pto speed should match up on the tachometer? You will know when you are mowing too fast, the mower will start streaking and lugging the tractor down. Ken Sweet
   / what speed do i run a 4ft finish mower #3
I ran mine at the 540 RPM (PTO) and in first gear. It feels slow, it is, but probably the best speed.
It would depend a lot on how rough the ground is, how familiar you are with the area, how thick the grass/weeds/trees are.
Go slow, be carefull !!
   / what speed do i run a 4ft finish mower #4
Many tractors have two PTO speeds, 540 and 1000 rpm. Many of the finish mowers will be running at 1000rpm.
As for ground speed that is determined by the height , thickness and type of grass plus the quality of cut you wish to achieve.
It's sorta an empirical experiment to find out what suits your needs.:D
   / what speed do i run a 4ft finish mower #5
Never ran a finish mower on my Satoh... the Woods RM42 mentioned using 2nd speed.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
1065 (A53342)
1065 (A53342)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
