What snowblower options for GR2120?
   / What snowblower options for GR2120? #1
Telstar2112
Walton, NY
Kubota L35, GR2120
I have seen people with GR machines list GR2728, GR2707 and I think a few others. Does anyone know what the differences are? Do the numbers mean anything? I will be possibly getting a used GR2120 this weekend and want to see if I can find a used snowblower for it over the next few months, but not sure which one I should be looking for. Any suggestions of what to look for or look-out for greatly appreciated.
TIA,
Steve
   / What snowblower options for GR2120? #2
I bought my GR2120 new in June 2013 along with a GR2728 snow blower. There was an update to the fan and hub of the snow blower, but I do not know if that made the model number change. My GR2728 has the updated fan and hub. Philip.
   / What snowblower options for GR2120? #3
TIA,
Steve
You'll want to be sure to get the subframe to hook to the tractor too, the blower is one piece, the sub-frame/quick front hitch is another....and is probably harder to find used, but you can get from the dealer new if you have $$$.
You can also look on kubota's website to see what attachments fit your machine.
goto kubota.com, choose US if your in the US, clicks on parts->illustrated parts->agree->type in your model (GR2120) and next to the model will be "local options", if you hit that it will show you all the attachments for that tractor. THe only blower shown is the 2707 two stage 48" blower. The subframe parts are part of the blower parts, but it is NOT part of the blower when you go to buy it, it's a separate kit because you can put the blade or sweeper on the same subframe/hitch.
   / What snowblower options for GR2120? #4
This pics should help. Philip.
Thanks, That is good information to make sure I get all the parts and I may not have realized it. Thanks! Agreed, I may end up having to buy some or all new. That looks like a pretty heavy duty setup. I am guessing it is raised and lowered by the hydraulics? It does seem like people have a few different model numbers but as mentioned above the 2707 is the only one listed in the brochure.
   / What snowblower options for GR2120? #6
It is raised with hydraulics. Uses the same lever/valve as the mower lift. If you look closely on the passenger side, you will see a hose, coupling, and cylinder. Philip.
Thanks. I did pick up that used GR2120 last weekend. 2014, 400 hrs and looks like new. Runs beautiful, power steering and glide steer are amazing, heavy duty 54" mower deck but... I will say that I am a little surprised that it did stop on some of the very steep hills (even with mower off). While I had read some of that on here it always seemed to be the older units and I thought (or maybe hoped) that it was fixed by 2014. The traction is amazing but it just stops, without any slowing down of the engine. Granted the hill may have been 40ish degrees, hard to judge that but pretty much as steep I would go without fear of tipping over backwards, but one of the main reasons for a 4 wheel drive is when you have hilly terrain. Do you have a similar issue? Should it be able to spin the wheels? (on dry ground). I plan to change the fluid and filter but curious as to what I should expect? I also tried pushing the pedal less as people act like that should help, kind of like a lower gear, but that didn't help and I found pushing it more gave it more power. I also saw the issue people had mentioned about the reverse pedal not having enough travel so I jury rigged that by removing one of the bolts to give it more throw and adjusted the stops a little, this helped a bit, but still would not make it up the hill. I was really hoping this would be a "go anywhere" tractor. Any thoughts?
Steve.
   / What snowblower options for GR2120? #8
I have never tried driving straight up a 40 degree steep hill, pretty flat here. I do mow a pond bank, but I mow that back and forth, then at the end I make a hard left and drive right up the bank. I have never needed to spin the tires on dry or wet grass, they have spun on snow and ice. Philip.
   / What snowblower options for GR2120? #9
Steve.
I had a GR2110 for a while, that climbed a ~45degree hill without issue. I believe the only difference btw the 2110 and 2120 is they replaced the problematic glidesteer cables with straight rods.
If it just stops, you might check your hydraulic fluid level in the case, you may be starving the hst unit of fluid. Also, some people seem to like to put cheap ATF (red or brown) in some of these hst tractors too, no idea why you buy a multi-thousand dollar machine and save $10 on fluid..but they do.....if it's not super UDT (should be almost clear) or at least real hydraulic fluid..it's likely to act up. I used to drive that 2110 up 50 degree ramps into my 4x4 pickup bed too, went right up, no issues.
   / What snowblower options for GR2120? #10
If performing HST fluid and filter change, remember to remove inlet screen and clean it too. Philip.
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
HYSTER H50FT FORKLIFT (A52472)
HYSTER H50FT...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
