What slip clutch for 3120?
   / What slip clutch for 3120? #1
Superduper
Platinum Member
Somewhere, over the rainbow.
John Deere 3120, Kubota BX2350, Deere X740
   / What slip clutch for 3120? #2
Yeah, that's it. That's a fair price, too. They're ~$85 from AgriSupply. They go on the implement. Be sure to adjust it when you install it as they tend to be fully tightened and/or painted stuck when new.
Thanks for the tip. I looked at the implement and the tractor and it seems to me that in order to attach the slip clutch at the implement side, the plastic shroud will need to be removed. If you look at the images, you'll see what I'm talking about. I would like to avoid that if possible for the sake of safety. There seems to be more room at the tractor side of the driveshaft. If anyone knows, is it OK to attach this device on the tractor side instead? Thanks in advance.
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
UNUSED XSTAR 101" X 25' BRIDGE PLATFORM (A54756)
UNUSED XSTAR 101"...
(INOP) 2020 KUBOTA X1100C RTV (A51406)
(INOP) 2020 KUBOTA...
1992 LANDOLL LOWBOY TRAILER (A51406)
1992 LANDOLL...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
