What sized staples for barbed wire on wood posts?
   / What sized staples for barbed wire on wood posts? #1
Timmer92
Minnesota
Kubota L3901
Hi all,
We're working on a pasture. The corners are going to have treated wood posts and support bracing. I'm going to use staples for the diagonal wire tension supports, and for the 5 rows of 12.5g barbed wire. At my local farm supply store the staples come in 1.25", 1.5", 1.75", 2", and 2.5". That's a crazy amount of choices. All are double barbed. Any logic here for what size to use? The smallest would seem fine to me but I have no experience.
Thanks
   / What sized staples for barbed wire on wood posts? #3
If they're too short you'll be beating you meat/fingers. I like the 1-3/4". I was thinking they were 9ga.
   / What sized staples for barbed wire on wood posts? #4
The width of the crown is based on what is being fastened...if it's barbed wire the smallest is fine...for the shanks...the softer the wood (posts) the longer they need to be...
   / What sized staples for barbed wire on wood posts? #5
Long is good, but keep in mind that the wire is to be kept in position, not secured to the posts. I want the wire loose in the staple so that air temperature extremes will allow the wire to expand and contract. Otherwise you risk having wood posts break when it gets really cold. I also use coil spring s a few times in the wire lines to help keep the wire tight and also lets it expand.
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
Blue Diamond 103709 (A53317)
Blue Diamond...
EZ loader trailer (A56857)
EZ loader trailer...
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
LOT OF SLINGS & CHAINS (A58374)
LOT OF SLINGS &...
