What sized staples for barbed wire on wood posts?
   / What sized staples for barbed wire on wood posts? #1
Timmer92
Bronze Member
Minnesota
Kubota L3901
Hi all,
We're working on a pasture. The corners are going to have treated wood posts and support bracing. I'm going to use staples for the diagonal wire tension supports, and for the 5 rows of 12.5g barbed wire. At my local farm supply store the staples come in 1.25", 1.5", 1.75", 2", and 2.5". That's a crazy amount of choices. All are double barbed. Any logic here for what size to use? The smallest would seem fine to me but I have no experience.
   / What sized staples for barbed wire on wood posts? #3
If they're too short you'll be beating you meat/fingers. I like the 1-3/4". I was thinking they were 9ga.
   / What sized staples for barbed wire on wood posts? #4
The width of the crown is based on what is being fastened...if it's barbed wire the smallest is fine...for the shanks...the softer the wood (posts) the longer they need to be...
   / What sized staples for barbed wire on wood posts? #5
Long is good, but keep in mind that the wire is to be kept in position, not secured to the posts. I want the wire loose in the staple so that air temperature extremes will allow the wire to expand and contract. Otherwise you risk having wood posts break when it gets really cold. I also use coil spring s a few times in the wire lines to help keep the wire tight and also lets it expand.
Heavy Haul trailer (A49461)
Heavy Haul trailer...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
