What size wheel (rim)?
   / What size wheel (rim)? #1
xmariner
Bronze Member
Bushnell, FL
LS XR4155HC
I have broken the front wheel/rim on my TU 150 FD. The Ag tire that was mounted on it originally is a 5x12 and the current turf tire is a 6x12.
Two questions: 1) what size rim is it and 2) does anyone have an idea as to where I might find one?
Thanks, Mark
Thanks for the advise, I'll do that.
Southern Maryland? I used to live in Leonardtown (my daughter was born there) and we had a house in Hollywood.
Mark
Terraformer, that's bizzare!
Sideways, I haven't seen that neck of the woods in years. We moved out of Maryland in 1978.
Update on the broken wheel - my mechanic routed out the cracks (each of the lug holes had cracks radiating out from the edges) on both sides of course. Then he welded each crack, front and back then ground the beads down flush. He then fabricated a "spider?" plate of 1/4 inch steel and welded it to the inside of the wheel. Now the hub "rests" solely on the 1/4 " plate. This fix/reinforcement necessitated longer lug bolts with new washers. Got both wheels reinforced for $200 less tax and new bolts. Hope it works well as the loader puts just that much more stress on the entire front end.
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
