What size wheel (rim)?
/ What size wheel (rim)? #1
xmariner
Bushnell, FL
LS XR4155HC
I have broken the front wheel/rim on my TU 150 FD. The Ag tire that was mounted on it originally is a 5x12 and the current turf tire is a 6x12.
Two questions: 1) what size rim is it and 2) does anyone have an idea as to where I might find one?
Thanks, Mark
Thanks for the advise, I'll do that.
Southern Maryland? I used to live in Leonardtown (my daughter was born there) and we had a house in Hollywood.
Mark
Terraformer, that's bizzare!
Sideways, I haven't seen that neck of the woods in years. We moved out of Maryland in 1978.
Update on the broken wheel - my mechanic routed out the cracks (each of the lug holes had cracks radiating out from the edges) on both sides of course. Then he welded each crack, front and back then ground the beads down flush. He then fabricated a "spider?" plate of 1/4 inch steel and welded it to the inside of the wheel. Now the hub "rests" solely on the 1/4 " plate. This fix/reinforcement necessitated longer lug bolts with new washers. Got both wheels reinforced for $200 less tax and new bolts. Hope it works well as the loader puts just that much more stress on the entire front end.
UNUSED JCT 84" HYD ROCK GRAPPLE BKT (A62131)
UNUSED JCT 84" HYD...
Vermeer 5400 Rebel Hay Baler (A61166)
Vermeer 5400 Rebel...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
John Deere 6300 (A60462)
John Deere 6300...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
