What size trailer hitch ball on a 16-18' deck trailer?
   / What size trailer hitch ball on a 16-18' deck trailer? #41
Usually they are a 2 and 5/16 but could be a 2 in I've also seen them in a pintle style depending on the weight of the trailer
   / What size trailer hitch ball on a 16-18' deck trailer? #42
I have a 6k, 12' tilt trailer with a 2-5/16" coupler:
   / What size trailer hitch ball on a 16-18' deck trailer? #43
@RickB There are a few still around but my area was covered with Sikeston MO 16 foot landscape style angle iron frame no gate, no ramp 2 idler axle, used car tire trailers direct from the factory for $900.
I picked up the only new 14' dual axle 7000lb landscape trailer left in Michigan (according to the internet) last Fall. 4 wheel brakes, only 1 set of shoes made contact with the drums, tire pressure ranged from a low of 6 psi all the way up to 20 psi, pinch style electrical connections that will hold up almost 20 minutes in the winter salt here in Michigan, wheel bearings packed by a one handed blind person and shiny black finish with more sand and weld splatter than Michigan uses for traction in the winter BUT it does have a 2 5/16" coupler.
   / What size trailer hitch ball on a 16-18' deck trailer? #44
I'd get a 14k lb. 2 5/16
   / What size trailer hitch ball on a 16-18' deck trailer? #45
Was just talking to my trailer dealer yesterday checking on my nephews trailer that he has on order. Asked about the 2 inch ball on tandem axle trailers, and was told that all two axle trailers over 12 foot are supposed to be 2 5/16 and the 2 inch 8K receiver trailers are supposed to be limited to 5K.
   / What size trailer hitch ball on a 16-18' deck trailer? #46
My 18 foot 7000 pound Load Trail with dual axles car hauler came with a 2 inch receiver, but on the website you can order them with either 2 inch or 2 5/16 inch.
   / What size trailer hitch ball on a 16-18' deck trailer? #47
Is that 2" coupler rated for 5K like mine was?
TRUCK FLATBED (A52472)
TMA (A49461)
TMA (A49461)
2004 KENWORTH DIGGER TRUCK (A52472)
2004 KENWORTH...
2008 JACK  130BBL (A52472)
2008 JACK 130BBL...
2014 ATC TRAILER (A52472)
2014 ATC TRAILER...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
