Security & Theft What size tarp
/ What size tarp #2
Why? Your just going to make it a mouse house....:2cents:
/ What size tarp
I’ve had decent luck with dryer sheets and I’m trying to shelter best I can
Trying to keep water out of Valve bodies and shelter from UV, etc
/ What size tarp #4
R&R in Hooksett NH has good tarps and Job lot also...
/ What size tarp #5
Well - with the backhoe attachment you might be able to make a half descent shelter. Be sure to "build" so that breezes/wind can blow under and prevent moisture build up.
/ What size tarp #6
One piece tarp going to be pain in the butt to cover tractor in the winter with wind blowing,maybe tube shelter might better until you decide on wooden cover.
/ What size tarp #7
Yes - I agree Thomas. Something temporary > perhaps made out of rigid plastic piping. Get the tractor adequately covered > get the tarp up and off the paint job.
/ What size tarp #9
When i had my lk3054 i covered it with a 12x20
/ What size tarp #11
/ What size tarp #12
I store my Kioti DK55 outside in the winter. I buy the heavy duty tarps from Costco. The ticket is good quality bungie cords so the tarp can move a little if the wind gets too strong. Rope will stretch over time and the tarp will get loose. The tarps are 12x16 before finishing. The blue tarps at the big box stores all say heavy duty but they are just single ply crap and based on experience, I believe they dissolve in the rain.
/ What size tarp
I ended up using a shelterlogic 20 ft by 10ft by 8ft canvas shelter
Put up on cinder blocks
I’ve used before and was trying to avoid putting it up but works perfect
Joel
/ What size tarp #15
Solid choice. I’ve run those shelters twice in my lifetime. First one last 4 years but had a second one right next to it. The second one only lasted two years in a wide open space. In case someone else comes across this post, I’ll second what someone else said, avoid standard tarps unless you plan on buying one a month. Ocean State Heavy Duty tarps have served me well and I finally found one I like. Covers my Kubota like a blanket. Four bungees with a light stretch is perfect. Tarps don’t like excessive force. 1695EA00-1B93-43C3-AACB-AEE9C52641A5.jpeg
/ What size tarp
That’s a perfect fit for sure! Nice looking yard and patio by the way!
2025 CATERPILLAR 255 SKID STEER (A65056)
2025 CATERPILLAR...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
213088 (A64276)
213088 (A64276)
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
PORTA POTTY (A68842)
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
