Rotary Cutter what size rotary cutter?
   / what size rotary cutter? #1
don4x4
CENTRAL FLORIDA
1991 kubota L2950
I have a 1991 Kubota L2950 with a LA450 FEL 30HP engine , pto 26HP. i was looking at the kingkutters. what is a good size rotary cutter for the L2950 and what size gearbox 40 HP or 60HP?
THANKS
   / what size rotary cutter? #2
You can use a 60" standard duty cutter with no problems, but your 3PH must be able to handle 700 lbs lifting capacity.
As far as gearbox size, since your PTO HP is 65% of the rated cutter gearboox HP (the 40 HP box), I'd feel very safe with the 40 HP box.
   / what size rotary cutter? #3
I'm with Roy. The 5' cutter with the 40 HP gearbox should work out fine..
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
Ford 655C 2WD Cab Backhoe (A55314)
Ford 655C 2WD Cab...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
