Rotary Cutter what size rotary cutter?
   / what size rotary cutter? #1
don4x4
CENTRAL FLORIDA
1991 kubota L2950
I have a 1991 Kubota L2950 with a LA450 FEL 30HP engine , pto 26HP. i was looking at the kingkutters. what is a good size rotary cutter for the L2950 and what size gearbox 40 HP or 60HP?
THANKS
   / what size rotary cutter? #2
You can use a 60" standard duty cutter with no problems, but your 3PH must be able to handle 700 lbs lifting capacity.
As far as gearbox size, since your PTO HP is 65% of the rated cutter gearboox HP (the 40 HP box), I'd feel very safe with the 40 HP box.
   / what size rotary cutter? #3
I'm with Roy. The 5' cutter with the 40 HP gearbox should work out fine..
New Holland TS100 Tractor (RIDE AND DRIVE) (A50774)
New Holland TS100...
6' King Kutter 3 pt Disk (A50515)
6' King Kutter 3...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
Kubota 2 Cyl Engine (A50774)
Kubota 2 Cyl...
