what size PHD for a bx-24?
   / what size PHD for a bx-24? #11
Hi UR,
Thanks for the clarification and more specific information. Good to hear from you!
Did Ron say whether that rig would run well on a B3030?
   / what size PHD for a bx-24? #12
I use a 9" x 32" auger on my BX24 and it has absolutely no trouble running it from the PTO. The 32" depth is plenty for most applications, and I have plenty of clearance when lifted. The 6" may be fine for chain link, but I still use the 9" for those too. I also just used it to bore 95 holes for planting 3 gallon arborvitae plants. There were so many small roots in the ground that the backhoe was almost worthless for the plantings, but using the auger made it a snap. A 6" auger would not have been big enough for the plants. Stan
howardx said:
My soil is pretty sandy, so i was hoping to use a standard 9" auger, instead of the compact tractor 6" version. I'll be setting some 4x4 posts for a deck.I was thinking the 6" version might be a little small for those post.What do you guys think?
   / what size PHD for a bx-24? #13
<<Have any of you guys used your Bh for setting posts?>>
I did this for two posts; actually they were 16" diameter telephone poles 14' length. I made the tightest holes I could, about 3 1/2 feet deep and it tooks 5 bags of cement each, plus a lot of rocks, to fill 'em up. Its pretty solid because I bumped into one of them pretty hard later. The hard part was raising the poles by myself. Altogether, about 4 hours per pole, mostly due to the pole raising difficulties.
Vince
Loader Arm (A51691)
Loader Arm (A51691)
2016 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2016 UTILITY VS2RA...
(3) PIVOT TIRES (A51244)
(3) PIVOT TIRES...
E-Z Flow Auger Wagon (A50514)
E-Z Flow Auger...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2018 LAYMOR SM450-ST SWEEPER (A51242)
2018 LAYMOR...
