What size earth auger bit do you use for a 4x4 fence post?
   / What size earth auger bit do you use for a 4x4 fence post? #71
Hmmmm, I'll turn that question around on you. How would you determine the minimum radious of a hole required to fit a square 4x4 into?
I wasn't suggesting you were wrong, but personally, I just pull out a measuring stick/tape, make a rough guess at corner to corner width, add 1/2-1" to each side of that value, pick the size auger closest to it that I have and call it a day. I don't normally have a calculator with me while I'm working - and no cell signal, so I don't carry phone. 2-way radio doesn't have apps like Calc either - actually it doesn't have any apps now that I think about it. 🙃😉😁
   / What size earth auger bit do you use for a 4x4 fence post? #72
How do you find the diagonal measurement?
If you are sinking posts, measure from either end. It's not like the post is already in the ground.
   / What size earth auger bit do you use for a 4x4 fence post? #73
I didn’t have a 4x4 handy but was at a computer 🤣
   / What size earth auger bit do you use for a 4x4 fence post? #74
My PHD's are "Armstrong Type". I've always sized my holes with about 2" clearance around the post, whatever the size. That gives me clearance to use my busted sucker rod tamping bar to give a very solid fit. I don't use foam. A bull with an itch would dislodge the post before he got it completely scratched.
   / What size earth auger bit do you use for a 4x4 fence post? #75
This is the way I always do my fence posts and ones I put in 30 years ago are still strong. Naturally, quality 4x4s that are treated with a good ground rating. This probably would not work in an area with much rock but here we have mostly clay and high ground water and lots of rain.
For a fence 4 1/2' tall i drill a 4" hole about 30" deep and then use my frontend loader to push the post down since the post is wider than the hole in the corners. Then I push or pound it down the rest of the way till it is 42" deep. If the ground is dry and hard I fill my bucket with dirt to give it the extra pressure it needs. This post will be very solid just like that but I fill the voids around the post with fine dirt or concrete with small aggregate. If your ground is very hard,
then you can drill the hole a little deeper than I do.
Putting the post in natural ground like that, the post will be much sturdier than if you dig a large hole and then try to pack dirt around it. The packed dirt will never be as hard as the natural ground already is.
   / What size earth auger bit do you use for a 4x4 fence post? #76
I suppose most of you guys have a tractor hitched auger but for anyone reading this from a search: I put in a property line split rail fence last year, number one son helped me with this. He's used a rental two man auger before so we went out to get one, old friend works there and said to get the self propelled wheeled machine, better for an old guy like me and not much more money. That machine is a jewel. Son was really surprised at how easy that machine bores the holes, especially in the pretty rugged area, no real lifting too. And I was thinking about hand digging? Might even be handier than the tractor hitch digger, and safer too I suspect. Highly recommended.
I've used both the single man hand held power auger and the one off the 3-point and unless I need a really big hole I prefer the hand one. Much faster to line up and easier to keep holes straight. If you know to keep it away from your body it doesn't beat you up too bad when it catches rocks and roots. If you stand close it'll pick you right up and spin you round. A lot easier to let it give if you hold it at arms length.
   / What size earth auger bit do you use for a 4x4 fence post? #77
I've seen 3x the size online but nobody seems to do that in real life. What size bit would you use for a 4x4 post? I will use either concrete or the foam stuff, probably the foam, so maybe the hole should be smaller diameter?
depends what size shovel you have really, it's digging out the dirt after you have bored the hole that matters' If you have a clamshell shovel probably 8 inch is good.
   / What size earth auger bit do you use for a 4x4 fence post? #78
When I build a wood fence, Use 1 1/2 inch clean crusher rock 4in on the bottom , set post, then add 3-4 inches of rock and tamp down hard, keep doing this until just above the ground....{always hard tamp] rock will go into the wood and the dirt..Post will last for years... My first fence I built in 1977 is still strong and steady... Just NO wood Rot... More work in the front door but worth it in the long run ...
   / What size earth auger bit do you use for a 4x4 fence post? #79
Large enough to get the post in and plumb. The hole is easier to backfill and compact if it is a little larger.
   / What size earth auger bit do you use for a 4x4 fence post? #80
I used an 8" auger. Still need to finish other side of road.
2013 Genie GTH1544 Telehandler (A59213)
2013 Genie GTH1544...
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A57453)
2004 Ford F-350...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
FENCE PANELS (A58214)
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2022 Ford Explorer 4WD SUV (A56859)
2022 Ford Explorer...
