the old grind
Super Member
- Joined
- Jul 21, 2012
- Messages
- 5,308
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
Drill bits are not reamers. DB needs a pilot hole to be only as wide as the bit's web. (AKA 'chisel' in the trade) The margin has no relief so doesn't actually cut when wobbled to enlarge a hole. Reamer also has no relief on the margin, removes up to .015"/side when hole is sized correctly.
Using a drill bit sized to slightly enlarge a hole is like reaming and puts all the load on the corners. (10+ yrs J-man toolmaker/tool grinder for GM engine & transmission plants, once 22k member UAW Local 599 is now just a retiree chapter)
Agree that a DP or better a mill is best to maintain hole size and location. Ream don't drill if hole is nearly to size. Carbide tooling (drills, reamers, burrs) can chip/break easily when used in hand drill & some (less rigid) DPs.
Anyway, back to what'll work this time.
