What size disk?
/ What size disk? #1
Springdrl
How should I determine what size disk I can attach to my 23hp tractor? It will be used to create food plots for deer.
Thanks.
/ What size disk? #2
I wouldn't go bigger than a 4' disk.
/ What size disk? #3
I think you could probably pull a 4' heavy duty or a 5' light/medium duty. I've used a 2wd 29 hp to pull a 6' medium duty. If it doesn't pick your front end up when you pick it up, you could probably go 5', especially if you have 4wd.
/ What size disk?
Thanks for the feedback. I was thinking too that any disk that doesn't lift the front wheels when you pick it up is probably going to work.
/ What size disk? #5
5' light duty with a 200+# weight is all my L2500 can handle(26hp). Depending on the soil the disk will bury the tractor. But it's a catch 22, untouched ground and you need a heavy disk to cut. To heavy and it's to much for the tractor. Shipping weight on a disk like mine is 500#, my FM is 525#. With my tractor a 4' is not wider than the rear wheels.
If you can use a 1-2 row subsoiler to break it up then disk. Search for some of my recent posts on my disk, subsoiler and plots. All I need for my plots is some water.
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
2013 CATERPILLAR TH514C TELESCOPIC FORKLIFT (A65053)
2013 CATERPILLAR...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
